Marco, if you used the valve springs as recommended for the camshaft i would use at least 6200-6500 area.
You may need more carburetor if your engine flattens out below 5500 rpms.
You need to test your WOT A/F ratio. The orifices below the power valve are probably to large?? You are looking at 12.8-13.1 A/F for best power. Bill
