Ill send you a pm to see if i can help at all.
Yea i have a narrowband o2 sensor, a one wire one (it doesn't work at idle speeds) lol im so cheap. I "turned AE off" by unplugging my broken TPS sensor. You can tell if its on or not by looking at the tuning screen and seeing if this gauge is moving when you push the throttle, if the AE is off it will stay at %100 all the time (its at %50 in the picture because the Megasquirt computer is off)...
AE gauge
Yours might be named differently...
For tuning with a datalog, its not to hard once you do it a few times. (im using a MS1, so it could be very different that what you need to do.) At first i was a little thrown off by there being no TPS reading (because mine broke), but once you get use to reading and knowing what the MAP sensor does and comparing it to the RPM and o2 Reading, you dont really need anything else.
For example, if you see this...
condition example
The RPM is at 1000 (very low,) the map is at 80 (means im almost full throttle,) and the o2 is at 0.0volts (means im very lean.)
You would want to increase the VE plot around these points... This is an old example, as this lean spot is not in my VE table anymore, but i would have increase my VE table in the 80's part of the MAP and the 1000-1200 rpm part. It would be in this area...
Example 2
Just a few % increase at a time.
AE gauge
condition example
Example 2
