Linc and MustangSix - yea for sure i will change the oil before i start it, there was a lot of gas that went into the cylinders I just got back from Napa where i picked up some new oil that i havent seen called "Wolf's Head" my dad said it was a east coast thing.
Also, i went around to all the parts stores in my area and no one could find the o-ring that i was looking for :roll: so i had to wing it. I picked up an assortment of o-rings and one of them fit remarkably well so i used that. I tested it and it holds pressure fine, if anyone thinks thats a bad idea tell me so i can hunt down a oem one.
I had the regulator wide open at first so that i wouldnt overpressure anything. Right off the bat the MSD fuel pump was running at ~15.2 psi. That is as low as it will go on 12v with the fuel system i have now. I thnk i will bump it down to 10v and work up from there. I should still be trying to start it later tonight, ill post if i do.
