Im making a list of what i have left to do, if you deside not to get the relay board then you will have to run the wires from your sensors into the car and combind them all into one DB37 end and connect that the megasquirt computer. With the relay board i have to run the wires to that (its in the engine bay) and run a db25 cable that you can buy and a computer place into the car and connect to the megasquirt. The relay board also holds a bunch of relays for you to use and looks very clean.
Drill and install o2 sensor
Drill and install air temp sensor
Mount Computer under dash.
Mount Relay Board in engine bay.
Run db37 cable from relay board to computer.
Get plug ends for most sensors (from website posted above)
Run wires from all the sensors to relay board.
Run rubber hose from fuel tubing to throttlebody
Run rubber hose from fuel tubing to fuel pump.
Run power to fuel pump
Get high flow fuel filter
Get oneway valve for fuel pump line
There must also be more that i forgot, theres always more.
