mustang652
Did a "dry" fit on the Offy 3X1 adapter on the "old" unmodified head today and have it running, obvioulsy only on the the center carb with the old linkage bypasing the Offy linkage and a jury rigged fuel line to bypass the triple feed lines which will be used when machine shop work is complete. . I Need some ideas on how to build the accelerator linkage for the Offy 3X1. Due to some setbacks on ths project and the related costs, I'd like to stay with the original pedal and rod if possible, even though I figure that the rod will have to be modified, bent, and or cut. The current rod crosses from the drivers side befind the motor and then comes forward on the passenger side to the middle of the block.
