need help with my header
stang65
Active member
hi
i have a 65 mustang with a 200 six
i want to install the header from mustangs unlimited
there are to 2 problems
1) i can´t get the starter out with the header installed
2) my carb linkage won`t work
its the original one
i have the autolite 1100
are there any solutions for this problems
i need pics of modified carb linkages
thank you
marcus
Well...There are a couple options:
Did you already order the headers?
1) If so, you probably won't be able to put them in, unless you remove the starter. Hopefully you won't be removing the starter a lot :D
If you didn't already order them, look into the ones on classicinlines.com ( http://www.classicinlines.com/products.asp?cat=53 )
2) I don't have any pics of a carb linkage, but I know if you do a search, you will find a LOT.
Marcus, there is a smaller starter motor that will fit - it's the gear reduction type made under several names for a different motor - maybe the 390? Somebody else will be sure on the "official" fitment.
I've seen many approaches for the linkage, from full cable setups, to part cable, to bent and re-formed linkage arms. My personal inclination would be to try remaking the original one but with offset dimensions to allow clearance. However, if time is important, a conversion to cable throttle may be the easiest.
Regards, Adam.
8)
IIRC you just a small race type starter for a FE motor. You can find them on Ebay.
If your header is not Jet Hot coated I would recommend a thermal blanket to try and keep the heat off the starter, will improve starter and life and make hot starts easier.
thanks guys
i cut the old linkage and welded it
the original starter fits
its tricky but ok
bye marcus
Great to hear you've resolved the problems. Did it end up being so hard as you had maybe imagined?
Holy cow! Simon's jumped the fence and spreading the 6 gospel in Germany. He's a moderator for that forum.
Silvercid":3jnciaxq said:
Ich finde die Idee eines 6 Zylinders - coool.
Alle jagen den 8ern nach - und Du schnappst Dir fein einen 6er - das ist VOR-sichtig!!!
[I think the idea of a 6er is cool. Everyone's out looking for 8s and you score a 6 big time. That is really looking ahead!!!]
I did a similar thing with the bar but I just bent it in line to reach over the header pipes in back.
All that worry for nothing.
