Google Neg. ion gen.(NIGS, from here on), and you'll find people selling air purifiers that are said to put out ion energy, and produce ozone. They'll compare it to the air during a rainstorm, waterfall or at the beach, and talk about how its refreshing, soothing, blah, blah, blah. Check out the science, it turns out ozone is a carcinogen. I don't care either way, not worried I'm gonna give my motor cancer, nor am I wanting to help it to feel "one with the universe".
Science does seem to agree on several things; NIGs do remove particulates from the air. They discharge a high voltage static electric charge (out the discharge needle array) which puts a (-?) electric charge on the particles, and they are attracted and stick to surfaces with an opposite (+?) charge, thereby cleaning the air.The units they sell for homes have a removable (to clean) plate behind the array.
This high voltage static electric discharge also seperates the water molecules in the air into Hydrogen and Oxygen, hence the talk of making ozone. Hmmm can you say Hydroxy? In a semi-closed system like I'm planning, it could also be said to be a de-humidifier, as the water in the air is turned to hydroxy, its not water any more.
What I've got isn't one of those finished units, its whats inside. I bought 4 units from Goldmine, a Co. that sells surplus electronic stuff.Its a plastic box with the electronics in it, about 2"x2"x 1/2", has a 2 wire cord to put an electric plug on, and has a single wire coming out that goes to a smaller plastic box, that has 4 1" long needles coming out. Its listed as 110v. input, 7.5K.V output.They had a 12 volt unit they were selling, but I wasn't sure it would do the job, and when I decided to mbuy, they were out.Being surplus, thats the way it is, which is why I got 4 of these units, @ $4.00 each. Besides, they wear out eventually.
The set-up; Structurally, like a cold-air intake, tho I might actually heat it, we'll see. Anyway, on top of the carb a honeycomb screen from and reccomended by Predator, whenever the air filter isn't right on top of the carb.Eliminates turbulence. A plastic elbow on the top of the carb, hooked to about a 3' plastic pipe pointing forward, with (maybe) an air filter on the end of that.Just back from that front end,(cause I don't like the idea of 7.5 kilovolts being discharged near the top of the carb) I drill holes in the pipe for the needles to poke thru, and down into the intake stream, and mount the array to the pipe. Could mount the other box to the pipe, as well, and then run the power cord to a switch, and from there to the inverter.
Now, the Ifs; Suppose I cut the pipe mid length, and splice in a 6" long piece of metal pipe, thats grounded to the frame, and take the air filter off? Think the pipe would have all the dust and dirt stuck to it, and none would go in the engine? K&N eat your heart out! A No-Resistance air filter! Would make any concerns about the carb screens being a restriction moot! From what I've gathered, I'm pretty sure 1 of these units is fully capable of handling 400 cfm of air.To test it, I could put an air filter 'after' the metal pipe, and run it that way for awhile, and see if the filter caught anything. Unlike regular air filters, I don't think the metal pipe could get full of stuff, (if I didn't clean it) and stop working. I THINK the charged dust particles would cling to the ones that were already there.If this works, I could design it so its easy to change out, and make an extra metal pipe.
On the water molecules, plenty of others have talked about how Hydroxy, as an accelerant, could speed the burn. Concern would be this; 1 day last week, here in the Phoenix area, the humidity was 5%.We're about to start our monsoon season, today its about 20%, and if we have a thunderstorm it would go to 90%+. Would different levels of hydrogen and oxygen make it difficult/impossible to keep tuned, or would it not make that much difference? Don't know.I suppose I could set up a water injection system to insure the level would be a certain amount all the time.Lets see, I'm going to inject water into the intake, so I can ionise it into hydroxy. Sounds a little patchwork, to me.
As a de-humidifier; I don't know that anyones ever run an ICE on de-humidified air.I think when people do water injection, it slows down the kernal speed a little, which makes sense. As the droplets of water are vaporised into steam, they absorb heat. Heat that would otherwise be vaporising gas droplets.So, it should, it seems, speed my flame kernal propogation, if the air is moisture free. Course there will still be some water in there, from the gas.Anyway, this is yet another thing I'm gonna try.Jim
