Over this week I pulled my head in anticipation for the install of my new OZ head. My car had been smoking for a while and we had tried every thing under the sun to get it fixed except change the piston rings. So with the head off we decided to pull the pistons and replace the rings. The cylinders looked in good shape on our first look. After pulling the first piston and cleaning it up and replacing the rings we started to hone the cylinder. Since this had been the cylinder that had been leaking oil into the combustion chamber due to the broken ring we paid extra attention to it. We discovered a small crack in the block!!! We sat there and contemplated what to do for a while. We decided to just go on with replacing the rings. After some debate over what to do we came to the conclusion we will just use this block and build up another one on rainy days, and replace it when the old one breaks even more or the new one is done. Ok so my question is, Is there a particular age/model of block I should look for to build up. I mean is there a difference like the head or are all of them basically the same? I would greatly appreciate and advice you could give me.
Thanks a bunch
Kevin
Thanks a bunch
Kevin
