dawnovsky
hi,
i have reset valves yesterday.
I had a compression test this morning.
cold compression are as follow.
Condition :
(dry cylinder (no oil added)
cold engine, WOT, value read after 4 compression cycle.
cyl 1 : 140 PSI
cyl 2 : 145 PSI
cyl 3 : 140 PSI
Cyl 4 : 135 PSI
Cyl 5 : 140 PSI
cyl 6 : 140 PSI
there are all in a 10 % range so i guess that s okay.
note : pulley damper is about new, it's single groove with an extra power steering pulley bolted over. i can tell it have not slide out as the dot on the inside damper still facing the one i have made on the outside to ease advance reading.
i have set the engine back to about 12°. it start but can t keep running. i ll surely have to readjust mixture since i have readjust valve
and there might sucks more air now.
Condition :
cyl 1 : 140 PSI
cyl 2 : 145 PSI
cyl 3 : 140 PSI
Cyl 4 : 135 PSI
Cyl 5 : 140 PSI
cyl 6 : 140 PSI
