Hi Guys, I`m new to this forum and retoring a 57 fire engine with a 223 line six engine in the Netherlands.
I hope someone can help me out here, got a rocker arm oil problem.
After taking of the cyl heads I removed the oil inlet tube, placed everything back and now there is no oil comming out of the inlet tube.
I do have 45 psi oil pressure at Idle.
I suspect a rubber seal at the bottom of that tube went bust.
Can anyone tell me if this seal is connected to the oil pump???
Can I get to it wen removing the oil pan/pump, or do i have to take out the engine?
Where can I get a new seal? I have all the part nr`s.
Hope someone can Help, everything is much appreciated!!!
Dan
Dan
