Didn't add the header because after the hot coating was done it warped. Hit the idler arm bolts and was only 1/2 inch away from the starter cable. We could have reheated and bent it, but then I would have had to re-coat it.
What I also have now is a backfire through the carb when I try to open the throttle fast and open the secondary barrel.
Seems like the accel pump is not squirting enough. Gonna get into a 5200 adjust post or site to see how to readjust it.
Just checked timing. Set it at 8 deg. btc. Idle is just low enogh to light the GEN light. Nice idle with the isky 262 cam.
