New Exhaust-lost power
hotrodbob
Got the 200 running. Had good power with stock exhaust. Decided to keep stock manifold but added 2 1/4 exhuast and flow master 3 chamber muff.
Now engine wont rev and has lost power. Do I need to rejet?
Carb is a Holley 5200 from Stovebolt.
Never heard another case of this. The log exhaust is so restrictive that a new pipe and muff usually makes a positive difference.
Sometimes when you add headers, an engine can run leaner. Maybe this is the case with yours.
Didn't add the header because after the hot coating was done it warped. Hit the idler arm bolts and was only 1/2 inch away from the starter cable. We could have reheated and bent it, but then I would have had to re-coat it.
What I also have now is a backfire through the carb when I try to open the throttle fast and open the secondary barrel.
Seems like the accel pump is not squirting enough. Gonna get into a 5200 adjust post or site to see how to readjust it.
Just checked timing. Set it at 8 deg. btc. Idle is just low enogh to light the GEN light. Nice idle with the isky 262 cam.
