ok I got my 200 together and got a starter in today....after spending the evening changing the pump drive (had put a 2.3ohc drive in by mistake and had to epoxy a rod to the end to get it out) I can't get it to fire/sputter/backfire I have spark that is nice and strong (pertronix in dual advance dizzy) I have fuel in the carb (can see it squirt) and I have compression. I am positive the cam is timed correctly (first ohv build for me....done timing on 2.3 lima motors hundreds of times) I can move the dizzy about 90 degrees and have retimed it a million times.....but it fails to do anything. even moving the dizzy while cranking produces no change in the cranking of it (doesn't speed up or slow down) I have a good cap and rotor and wires (spark on a pulled plug) but it fails to do anything. so does anyone have any good starting points? I have done 5-6 motor swaps before with no ignition probs ever always fired on the first try basicly (unless I forgot something like a rotor or coil wire) I need to get this started before friday because I need to drive it back to school this weekend and I would like to get 50-100 miles on the motor before then
