barishiman
Ok, so I finally got replacement roller-tipped rockers and tomorrow I plan to start the engine in four months. I have some grease that I plan on putting atop the valve stems and pushrods to eliminate friction. I've taken out the pertronix unit and put the points back into the 67 dizzy.
Now should start the car with the new 67 dizzy or the old 65 dizzy? Will there be a difference? maybe the vacuum lines? Also on installation, it should be this:
the 1st piston should be TDC and in the revolution of the intake valve opening. The dizzy rotor should be placed before the 1 on the dizzy cap prior to firing the engine.
I plan to keep the pushrods loose and will do a compression check if I can get the engine to run. Is there anything I'm missing or not clear about?
Thanks again!
Thanks again!
