Hi all,
Newbie question. 65 Mustang 200 I6, Autolite 1100, Pertronix II, Pertronix Flamethrower coil. I recently got this car, and never checked the timing prior to putting the Pertronix unit in. It would idle roughly when stopped, in gear, like at a stop light. I wanted to find out the timing, so I bought a light. I disconnect the vacuum line, and hit it with the gun. It was WAY past (above) the timing marks. Must have been 25 degrees or more. I rotated the dizzy to get the timing to about 12 and reconnected vacuum. Once I got it to idle well with the lean/rich setting and idle setting, I took it out for a spin. Very poor acceleration and it wouldn't shift well (auto). I got it back, and reset it to about 16 degrees. This seems to be a good compromise, although the acceleration and shifting aren't what they were at the setting initially.
is this typical?
cheers,
MrM
is this typical?
cheers,
MrM
