Hey guys- I have a 64 falcon that I just put a newly rebuilt 68 200ci in. It is bored .030" over, standard pistons, mild cam, over than that, everything all stock, but new. It has brand new hoses and a brand new radiator. It comes up to temperature pretty cool and then gets REALLY hot. It pegs the stock gauge (idiot light w/ a needle), but I got an infrared thermometer and measured at the thermostat housing I was getting up to like 215* before I shut it off. Timing is set at 12*. It has an electric fan with a ground sided temp switch installed in the thermostat housing. The fan works fine, although part of me is wondering if I need to either get another fan or a better one that pushes a little more air. It is mounted on the front drivers side of the radiator pushing. Depending on what you guys think, I may try to get my hands on a box fan to put in front of the car and see if my problem goes away. If it does, then obviously it's an issue with my fan. Thanks for the help guys!!!
