I have a 200 electronic ignition and MSD6, 3.55 rear. If I make a 2 barrel carb and fashion a plate for the log, use an adapter like mandarina has and pump in the nitrous, I have a question.
knowing that I need to run wide open throttle, I have a t-5, I won't be able to throw the nitrous switch until that t-5 is in fourth correct???
Obvious other modifications would be:
1. driveline safety loop
2. fleat top pistons (no edges to get heated up)
3. modified cam and retard the ignition
