Not sure on the screw. Where is it located?It can take a lone time to get oil there ,it is the farthest place to get oil...Try a faster drill and more time.
The screw in oil galley plug behind the cam sprocket is in place, right?
there is oil coming out at the gauge port. I took rocker arms off so I could see the hole where the oil is supposed to come out. There is oil coming out after about 30 seconds but it is a fairly low volume of oil, how much should be coming out, I thought it would squirt out.
Thank you very much. I will take the cover off and check and see if the plug is inView attachment 8848
See the screw in plug by the cam retainer bolt hole that is it..If it is not there oil will pour out unseen and oil pressure will be very low..There is one like it at the rear, but if that is missing, oil will leak out the bell housing .I would remove the oil pressure sender ,plumb a gauge and find up how much pressure you can get with the drill ..Remember it takes a long time to get oil to the rockers.
The plug was not in. I looked through the box that I put all the nuts, bolts, and various small parts in and saw it. Put it in, reassembled timing chain cover, and now when I run the drill I have lots of oil dripping out of all the rocket arms.Thank you very much. I will take the cover off and check and see if the plug is in
First entry with this group and turned out goodThe plug was not in. I looked through the box that I put all the nuts, bolts, and various small parts in and saw it. Put it in, reassembled timing chain cover, and now when I run the drill I have lots of oil dripping out of all the rocket arms.
thank you very much for the help
