mr.mustang
I recently put a DSII on my car with the GM module. i did not remove the pink wire from the ignition switch. I got the car running but took out the distributor to have more room to move it (should have just change the order in the cap) but when i tried it again there was no spark. my question is that if the little time the car was on blew gm module (check coil seems ok) or if the first time i got the car running was- that by chance the coil even with the resistor gave enough power so the dsII could work. I bought a new a breakerless coil, gm module and going to run a hot 12 volt wire to the coil, but still am wondering why it does work anymore with the current setup?
