ok no9w i got the motor in i replaced all the standard stuff off the new motor with the tryed n true stuff off the old motor, everything is fine cept no %^&(*$ spark, i tore the dist apart n cleaned n sanded and regapped , then took the light n checked the wire to the coil againnst ground n got a lite, tested the dist against pos and got lite, got a slight spark coming from the coil but nothing to the spark plugs , what next should i do?
