When I got to the Fairlane Nats in York this past Friday, it became painfully obvious that my 29 cubic foot trunk isn't big enough as the wires for my 3rd brake light had been pulled out from all the stuff. And York is only about an hour from where I live. Next year the Nats are in Dearborn and I should have the efi swap taken care of which means my battery moves to the trunk. Once that battery is back there I won't have enough room.
So my solution is to rent a u-haul trailer or something. The problem with that is although I wouldn't have any problems on the flats I'd have problems in the hills and mountains. Western PA is practically only hills and mountains. As much as I love my car and the fact that it's a six, in its current form it doesn't have the power to pull itself, 3 people, and a u-haul trailer through the mountains while maintaining anything close to highway speed.
Which brings me to the power issue. In order to pull the trailer I'm probably going to need to squeeze out every possible ounce of power from not just the engine but the entire car. My thinking is the tempo efi combined with using e85 will help somewhat, but not entirely.
I'm also planning on installing an electric fan so I can ditch the crank driven unit to free up a little power. Further I'm highly considering switching to full synthetics for the T5 and rear axle, and, if I can find this bloody oil leak, fully synthetic for the engine as well.
Mainly to improve handling but it should cut down on drag is lowering the front of the car roughly an inch so the car can sit level without the air shocks (yes I know, the trailer will probably add more drag than the slightly lower stance will remove but at least it wouldn't be a total loss and I will have to retain the air shocks to sit level with the trailer)
I need some suggestions on what else I can do with the car to get the additional power. Anyone?
