mustang652
Have spent the past two days trying to get the car running properly and I'm about ready to shoot it and put it out of my misery. Today was spent with a friend who is a retired mechanic. Several years ago he had built and owned a 200 CID Mustang with the Offy system. Even he could not positivly pinpoint the problems.
At idle it sounds great and has excellent throttle response. I've got initial timing at 14 degrees BTDC, plugs gap now at 45 (had them at 35 until a couple of hours ago, after the regap to 45 it did improve the running a little)
I do have the Dizzy II out of an 81 Zepher, but it has not been recuved (Next month's project}. Under load, it bogs down and sounding like it is missing on at least one cylinder, and not much power. I've checked and I have fire to all cylinders, and it sounds the same on two different set of plugs, and plugs are black in color. An application of carb cleaning spray on the end of the throttle plate rod indicates I do have a bit of a vac leak on at least two of the three carbs. My friend thinks this is the majority of the problem. In asking for help and advise, I also ask, can there be somthing wrong with the distributor or the control box? I had what seemed like a simular problem even before I put the OPffy adaptor on the head. While I was testing out the carbs I rebuilt, I ended up with what sounded like a miss, new plugs at the time helped but did not cure the problem, assumed the problem was with the old head. I'd like to try to get it running well enough by Friday to take it to an MCA show. Even thought it's in the early stages of rough sanding and looks like crap, I really wanted to show it as one of the alternative that can be done with an I6.
I have run out of idea and would appreciate any help.
