Timnmelinda
Got no response to a shorter air cleaner for 32/36 carb
so New question
What would be a shorter carb upgrade the 32/36 is really tight on space in our mustang, not much room even without an air cleaner, so for example a holley set up any shorter? Using which adapter?
Can I modify stock linkage for it or will I need to go to cable (I realize almost anything can be modified to work but I mean reasonably and quickly)
How will performance/economy compare to using 32/36?
While I am at it should I do carb upgrade or wait till I build next engine?
Current 200, headers, 2 inch duals with crossover, DUI other than that stock.
Will see if This phrasing can get any feed back!
so New question
