The peak HP was @ 4200 RPM just as a stock 200 would have peaked at that RPM too! Remember this 200 Block is Stock even the Cam!
MustangSix":283slwj8 said:There are probably a few more horses (maybe 10-15) to be found by going to a Holley 350 instead of the 5200. Maybe a 38 DGES would be good.
Does your distributor have mechanical advance or is it the old vacuum only unit. If it's the vacuum only, there are at least 5 more horses hidden there by switching to a later dizzy..
Mustangaroo":piasiyge said:My son is pulling his engine Friday 12/13/02 for a complete rebuild, Aussie 2V, 256 ISKY cam about .450 lift, headers, 350 or 500 Holly, balanced the engine and with a CR around 9:8.1......Then we DYNO it after she gets broke in! We'll post all the numbers after we DYNO both engines!
the result was 105 HP at the rear wheels.
