Overcooling?
Okay, so I acquired and tested a 195* thermostat and installed it. The thermometer read over 180 in the radiator like it's supposed to, but the temp gauge still read at the bottom of the normal range, so I pulled the sending unit out and cleaned it and cleaned its hole. There was some crud in there.
I then found an old spare that I had sitting around. I compared the resistance of the two at room temperature, and it was approximately 235 ohms in the spare and 405 ohms in the one I had been using. I then set them both in some water on the stove and heated the water up. I didn't bother to check exactly how hot it was but I would guess it was around 150*. The spare read 37 ohms and the one I'd been using read 63 ohms.
So I decided to just install the spare unit. I didn't use any thread sealer of any kind because I read things online warning against it. It doesn't leak a drop. Now the gauge moves up to the bottom C line when I turn on the key with a cool engine (it probably had some residual heat, but I don't know how much) and points between the T and the E but closer to the E of the word "temp" when fully warm on a 62* night.
I thought it would be best to have the gauge operating as accurately as possible because that way I'd have a clue when/if it ever actually got close to overheating. Does it sound like mine's calibrated about right?
Sounds about right. The main thing is that you know where it normally operates so you can tell if it changes significantly.
Joe
You're gonna get this temp thing whipped and once you do, you'll find something else crop up that will be whole lot more complicated. They made the car to run without modification anywhere from northern Newfoundland to Arizona.
If you are really concerned about the temperature, get a direct reading aftermarket t-stat. The needle on the dash gauge sits somewhere normally and goes up past there when it is hot. If you had a 65, it would only be a red light without marks that goes on when it gets too high.
Got it. I'm satisfied with the way it is now so I'll go ahead and leave it alone.
Thanks for the help, everyone.
