Steve,
The set up is still the same and I've extremely happy with it. Stock look on the inside (looks just like the normal pedal) and clean look on the outside. No worries about fire wall penetrations since the V-8 pedal goes right into the I-6 spot and uses the same hole. Only difference is the bracket is oriented different and just requires to put in 3 sheet metal screws where there are already dimples on the firewall (at least mine had them).
I'm used a Holley 4V 390CFM vacuum secondary carb. I forget the model number off the top of my head.
For the cable, I believe I used the 36" version, but I did have to trim it some. the 36" cable should be long enough for routing for any type of applications, Offy, Oz250, AL, 2V log, and stock.
http://www.lokar.com/product-descriptio ... cables.htm
I bought mine from a local parts house.
Only down side was return spring locations. I'm not happy with where mine are, but mostly for appearance reasons, they function perfectly. When I replace the clutch pedal I may place a return spring on the pedal under the dash versus in the engine bay.
Mike, the kit looks easy, but what's the price. Looks like it would probably run about the same as buying a V-8 pedal and standard cable conversion kit.
