Ha. I learned that the hard way yesterday. It was clear that I needed to remove the pins once I tried to put the block plate on. I tried and tried and tried to remove them but they were really stuck in there. The engine is still in the car so I had limited access. What I decided to do was put white out on the pins. I then put the block plate on so the white out would rub off on it. Next I took the plate to my drill press and drilled out new holes, so the plate could fit on. However, after test fitting the bellhousing, it quickly occurred to me that one of the pins could not stay there as it interfered with the bellhousing covering properly. So, after already installing the flywheel, clutch and pressure plate, I had to carefully drill out one of the dowel pins. I then ground it down smooth using a dremel. That added several hours to the job yesterday, but I’m happy with how it all turned out.
