The best tool I have found for gripping round objects or rounded fuel or trans. line fittings is a pair of "Channellock 410" parrot nose pliers.
They will loosen a rounded fuel or trans line fitting when a tubing wrench won't.
I won't try to remove a dowel pin on the block a have because the hardened teeth will damage the dowel pin.
The harder you pull these pliers the tighter they grip.
If the block was heated with a propane torch these pliers might remove a dowel pin. The damaged end might be filed then that end might be installed in the block. A better Idea would be to buy new dowel pins in advance.
Any way these pliers are great to have.
I see them for sale on Amazon. I bought mine from a Snap On Truck.
Channellock 410 parrot nose pliers.
Self Gripping Parrot Nose design ideal for round surfaces.
Right angle, laser heat-treated teeth grip better and last longer.
High-carbon C1080 steel for superior performance.
