Anlushac11:
I dont see how you could use them.
The 250 and the 200 have a different compression height, the distance from the centerline of the piston pin to the top of the piston.
You are right about the Aussie 200 and 250 (3.3 and 4.1) piston being taller than the stock US 200/250 piston (1.60 verses 1.50"). But they are exactly the same compression height as the Topaz/Tempo and 255 V8 pistons, which are used in sixes too, so they can be made to fit easily.
Note that all pre 1970 Aussie engines (188, 200, 221) had US style 1.50" compression heights, and there are still replacements around for these.
Ford USA purposely made the American pistons park 50 to 100 thou below the actual deck of the block, possibly so the production tolerances and compression could be looser. On the Aussie engines, pistons parked more like 20 to 30 thou below the deck at top dead centre, and had pistons with much more dish.
The ACL Race shallow deck pistons are much shorter than this, and can fit up to a range of longer rods. I am certain a rod swap and longer rods whould be cheaper than forged pistons alone.
I'm with gm destroya. I'd spend more money on avoiding the detonation contition by dyno tunning, rather than shovelling more money into forged pistons.
American options:
2.0 Pinto Forged pistons are getting pricey, and it's hard to find +120 thou numbers (3.695") any more. And then, they are taller than most Aussie, Topaz/Tempo/255V8 pistons.
229/305 Chevy forged piston's need a 56 thou overbore to fit, and if you are worried you'll ruin your original block during the boring phase, and theres a small chance it will, then your only other option is Subaru 1.22" forged pistons with the Ford 2.0 Pinto rod.
Then there's Wiesco, Ross, Arias or possibly Jet custom pistons. A set with a real short deck of about 1.1" would allow you to use modified 289/302 Boss con-rods in a 200 I6.
Phew. Things to go with things again.
