I need some advise on what parts I might need for my 250 rebuild. I would like to get more out the engine and am aware that the cam, valve assembly, exhaust and carb are all inter-related.
I have the dual outlet header and dual exhaust system already. Given that I would like to use Mike's new head, what cam, valve assembly and two barrel carb I might need.
- Would it be better to go 1.6 lift, roller tip or full roller?
- What diameter valve should I use, as Mike lists two different sizes? Springs?
- What cam would be best to use? I would like a bit better performance, still fairly smooth idle and I need some vacuum as currently I have power brakes and steering.
- I am thinking of using a 2bbl carb, are there reasons to go 4bbl, which 2 bbl would work?
I am sure I have missed a bunch of stuff, any help would be much appreciated.
Jim in MO
Jim in MO
