t-west
Hi all,
Now that I've had more time, I'm trying to finish my project. I haven't started her since about November, and after charging the battery, I get nothing but a click, as if the starter is pusing into the torque converter, but no spin.
So far I have:
By the way, all the lights have been removed to get ready for paint, not sure if that matters.
best,
--tom
So far I have:
- taken the starter down to Kragen and it tests fine.
- replaced the starter ground to the firewall with a new one (old was crusty and sheath was broken in several places.)
- swaped out the solenoid for a new one.
- checked the coil, getting slightly less than 12V (new Flamethrower coil w/ DSII system)
- double checked the neutral safety switch setting (one of the bolts was a bit loose.)
- hand-turned to crank to make sure it wasn't seized up.
- getting same reading from coil to module
best,
--tom
