plenum ?
mustube
i was just wondering what the best way would be to join the airflow of 2 turbos for multiple carbs, i was thinking a plenum but could you have an inlet at each end of the plenum or would that cause flow problems?
I've wondered about turbo on an Offy setup on a log head. Tuning all three would be a royal pain though...
the only real benifit is on a offy (progressive style) you can jet the outter carbs rich to provid more fuel under boost (you are only going ot build boost at higher engine loads/throttle)
