CZLN6":3r5sxz11 said:
Howdy Back Mustube:
NO, it does not sound right. 1.Are all of the plugs black? 2.How old are the plugs? 3.What heat range? 4.How new are the plug wires? 5.Is this a change since the last time you checked the plugs? 6.When was that?
7.How is the engine running? 8.Any changes in performance lately?
9.How many miles/years on the engine? 10.Does it use any oil?
Given your location it is unlikely that you will ever need to use your choke. 11.Is it set lean?
Keep the info comming and we'll get this figured out.
1.yes all of the plugs are black
2.I have no idea how old the plugs are, they were on the car when we bought it and it has been at my grandpas farm and i just brought it home a few weeks ago.
3.i have no idea, how do i check/how would i know?
4.same as the plugs, they were on the car when i bought it
5.havent checked the plugs before
6.this was the first time
7.the engine runs DECENT when warmed up well, you have to keep on the gas for about 30 seconds when you first start it up to keep it running, if you dont the engine will die, it sounds like its missing a little when in idle but that seems to go away at higher rpms
8.its been like this since ive bought it this is just the first time ive had the car in front of me to fix the problem
9.the engine has been rebuilt one time before but do not know when that was, the car shows 68,xxx but im pretty darn sure that its rolled over at least if not twice.
10.it doesnt use any oil
11.it is set to where it idles the best but it is rich i think (whichever has more gas).
