The Vaporizer is an excellent choice for replacing your old Autolite 1100-1V carb. For stock applications or mild performance engines, the Vaporizer is tough to beat. Dyno test have shown the Vaporizer to increase horse power by as much as 20HP, however one can normally expect to see gains around 10-15 HP in most situations. You can also expect to see an increase in your mileage due to the Annular Fuel Discharge boosters, which atomize the fuel much better than the older carbs, especially at idle and lower rpm's.
As we said earlier, if your planning to keep the stock Load-O-Matic distributor, you need to order the early version (63-67) with the Spark Control Valve. However if your planning to upgrade your ignition system, we recommend ordering the later '68 version , which comes without the SCV. This allows you to use the Duraspark II distributor, the DUI distributor, or another aftermarket distributor such as Mallory.
