After about a year hiatus,. I've started back on the mustang. Im picking up right where i left with the rolling resto on it.The first order of business was to put on my new carb. Reasons for new carb; PO put on some other carb that wasn;t orignial so i want to go orignial. And the old carb that was on it was nasty and didn't run right. So i put the new carb on, fire it up...
Runs like a beauty in park and neutral. But as soon as it goes into reverse it stalls. The same with Drive. I know its not my vaccuum advance. I have already put a new one on. The old one was cracked and torn BAD. But could it be a vaccuum leak someplace else? If so how/ where do i check it? The line going into the carb from the vac. adv. is kind of not in very far. I think this is because the fitting is so large though. It seems to be a good tight fit. And suggestions or comments ???
