I am looking for some pushrods. I need them for an adjustable rocker arm assembly, so they should be ball and cup ends. Is the overall length of 8.070" correct? Anyone who used adjustable rockers with a milled head do you know what part numbers you used?
Is the pushrod length the same for a 170 as for a 200?
In other words can I use the adjustable rocker arm assembly and push rods from my 170 for my 250 2V head and 200 block when I build for my engine swap?
Yes you can. That is the reason for using the adjustable setup. You are able to adjust them to the correct tightness for the pushrod length. You can also adjust the arms to compensate for milling your head in case you did mill.
I believe most or all of the guys running the OZ heads have a adjustable setup. or the neato roller rocker setup on some heads..
