Question about using header flange as base
Anlushac11
1K+
I have a tubular exhaust header I bought used.
I want to cut the header tubes off and use the flange at the block as the base for building a tubular header for my turbo setup.
I know the tubing needs to be robust and I know I need brackets to hang turbo from so as not to stress the tubing with the turbo weight.
I have seen some people say that the header flange would not be strong enough to use with a turbo.
I was planning on using parts from this place.
http://jgsturbo.com/index2.html
Anyone have any comments or suggestions?
