The cap would need replacement if there are any carbon tracks or burned areas around where the coil mounts.
The main concern is use nylon rotor retaining fasteners & inspect the centrifugal weights below the rotor.
Because of the high electrical field in the rotor area you need to lube the advance weights at the pin & where they contact the advance cam. If left unattended rust buildup is very common in this distributor in the advance mechanism area. Falcon Man
