mysavioreigns
I'll try to explain this as best as I can:
On the H/W 5200, there are 2 tubes (next to each other) coming out of it that appear to be for vacuum. One comes straight out and has a flare on the end, and the other comes out and makes a 90* turn and does not have a flare. both are 3/16"
So, I had the hose going from the distributor to the straight one with a flare on it. Went to replace the hose, and the dang nipple broke off. So, I plugged it, and went through the other hose. That was the only thing that changed, and the car is acting quite different. Did I go to the wrong tube or something?
