Mercury Mike
and I'm still a bit confused. I have the control box mounted, the distributor dropped in @ TDC and ready to be timed. I have the clip on the coil, all of the connectors are plugged in, and now I come to the wiring up. I have been reading all of the diagrams, and I think I kind of understand it... but I don't wanna have a field day with wiring and waste my time or screw something up. There's a red wire that comes from the coil bracket. Where do I hook that up? Do I solder it to the wire that was going to the original coil? And then the red and white wire from the connector coming from the control box... the red goes to the ignition switch, on the run tab, before the ballast resistor? And the white wire goes directly to the S Terminal on the solenoid? And do I leave the wire that's on the S terminal now on there? Just give me a quick wiring plan and I'll get to work! Also, there are 3 wires coming out of the male connector that goes into the female connector on the control box with the red and white wires coming out. Where does the third wire go? Thanks guys and gals!
