Rear cam plug
ledslinger29
Do I have this thing installed right? It's not backwards is it? The old one came up missing after the magnaflux and hot wash
This is looking from behind the block
such a close up hard 4 me 2 tell. Looks a lill deep, no?
Hey,
do U have the part numbers for the rocker shaft plugs?
It is fine, no pressure behind it, and plenty of space for the cam, however, it is set deeper then you would want for a coolant, or oil gallery plug (for future reference, they should be set flush with the block, not below, like that one)
drag-200stang":1v3tf8p9 said:
I think it is good too.. :thumbup:
Did you get the front oil galley plug in yet, it is easy to miss?
You're about to tell me this is the front oil galley plug and I don't have one aren't you?
No not there, it is behind the cam sprocket...You should be able to see it if you look closely...It is inline with the threaded one in the back of the block...It is about 1/2'' sized knock in plug...It is above the upper cam retainer plate bolt and to the left at about 11.30
