how do i know which rear main seal i am to use? it has been well over three years since i have had my motor apart
and i cant remember if it had a rope style or a plastic rear main seal. well i am now at the point of assembling the short block and dont know which to use. will either work? is one better than the other? the motor is a 1966 200.
i have had it bored .040, 10-10 the crank, balanced and i have flat top pistons and arp rod bolts installed. not sure which cam i am going to run yet but would like to hit 5000 rpm without too much concern. dual rooler timing set from you know who 8) and a 75 head. plan to buy header for it, also from same guy.
will also run a t-5. this setup will be in a 66 falcon.
i hope to be done with this PROJECT in the next few years. yes i said years
i hope to post some pics one of these days.
thanks, rob
thanks, rob
