I'm replacing the main bearings on my "68 block [200] while it is in the car. Since I disturbed the rear bearing cap which holds the rear crankshaft seal I am wondering if I should replace it to guard against leaking [ it wasn't leaking prior to changing the bearing ]. Can the rear main seal be changed without removing the crank while the engine is in the car? It appears to be a two piece rubber seal. Or is it best to leave it alone and hope it won't leak?
Thanks
Russ
Thanks
Russ
