Here's how it works:
1.) Module-for-module, you can plug the Yellow Grommet Duraspark into the harness where your blue or black grommet module is now. The only thing that will change is the dwell: it goes from 42 degrees (blue module) to 45 degrees (yellow), which makes the spark a little hotter. Static timing settings do not change.
2.) Add the vacuum sensor to the Yellow grommet module by just plugging it in (do this ONLY when the ignition is OFF). Don't hook the vacuum line to it yet: start the engine and you will see the timing is retarded about 4 degrees from your "normal" setting. Now, adjust the distributor until your original timing is restored (in other words, you're adding 4 degrees advance to this setting).
3.) Kill the engine again. Connect a vacuum line from the vacuum sensor to MANIFOLD vacuum. Start the engine and you will see your original advance +4 extra degrees. This will make your idle faster, so slow it down at the idle adjust screw.
For example, my Fairmont uses 10 degrees BTDC static advance. Plugging in the Yellow Grommet module changes this to 6 degrees BTDC. Now, I adjust the dizzy to 10 degrees BTDC with no vacuum on the sensor. Next, I plug in the vacuum line and get 14 degrees advance at idle. When it starts, it starts at 10 degrees. If I stomp the throttle from idle, it drops to 10 degrees until the dizzy starts adding it's advance. All of this is IN ADDITION to the vacuum advance in use on the distributor: altogether it still does not generate any ping.
Here's what happens: whenever you are driving under LIGHT LOAD, like 30-40MPH city traffic or idling, the Yellow grommet adds 4 degrees of advance to improve efficiency. This saves gas by adding engine RPM to the throttle setting you are using. When you accelerate enough to drop the vacuum to about 8"-10" Hg, the extra advance drops out so that you don't get ping. As soon as you let up on the throttle, the advance returns for better MPG.
When starting, the Yellow Grommet module backs off to the "no vacuum" setting, which is your normal static timing.
My Fairmont gains 1-2.5 MPG with this setup, depending on how aggressively I'm driving....
