I went out to try to start my motor today. This was the most effort I have put into trying to start the motor. Since I have put it back together, I haven't had much time to tinker with her. I have plans to take a few days off from work to really get into it.
Any how, this is what she was doing:
When turning over, the motor will try to fire when I slightly press on the gas pedal. When I think it's going to fire, I back off the gas and the motor sputters a little and dies. I have a new dizzy with the Ignitor II and the flame thrower coil. From the sounds of it, the dizzy and coil are working proerly. I haven't made any adjustments to the carb as far as air/fuel screws or idle screw. It is as it was when I took the carb out of the box. Should I richen the air/fuel mixture? Where should I try to set the timing? Should I open the choke?
I want to get the motor to the point where it will run on it's own. Once I get to that point, I will adjust the idle screw to 2000 to 2500 RPM in order to break in the cam.
Any help would be greatly appreciated.
Ted
Ted
