I finished the adaptor and have everything bolted up. I have adapted an Autolite 1100 to a '78 head w/the 1.75" intake. It idles and runs great, and I can't tell a difference from the Holley 1946 I was running except in very hard acceleration. By that, I mean literally stomping it to the floor. Now, I realize that I won't be driving it that way (at least not much, anyway
), but I want to know what's causing this. This hesitation is only for a split second, then the motor revs up as usual. Is this a normal thing for the 1100? I have been through 2 or 3 carbs. a few years back, and they did the same thing.
I adjusted the idle mixture, and it helped a little.
A mechanic told me that the hesitation was causing by the adaptation, and that the small carb. on the large intake would work good. But, I don't agree. It seems like that would make no difference since the 1100 was originally used on these engine w/the small intake. With the correct adaptor, it would be just like running it on an older head w/ 1.5" intake.
What do ya'll think could cause this?
