Timnmelinda
Need ideas or suggestions
Bought my 67 Mustand/200/automatic 42,700 miles
no smoke no signs of oil use
restored car
upgraded to headers and duals
still no signs of oil problems
changed to dui distributor, did oil n lube change on car in the process overfilled oil 1 quart, corrected oil level and car smoke a lot at idle.
Seems to disapear wit rpms raised but at idle it is visible
ran the car a while to eliminate possible smoking from prior oil over fill
still smoking at idle, do not know what to do / look for now, I am out of ideas, would not think with 43000 miles it would be rings, and it appears to stop with rpms, do not think valve seals because when it is running and warmed it still does it.
Any ideas or experiences you can share?
Tim
restored car
Tim
