Later 1100 carbs without the spark advance valve cannot be retrofitted with the valve without majot work. The casting will still have a hole, into which the spark advance valve would have been threaded. But the casting is raw, no threads etc. The internal passages are not drilled out either. According to ponycarbs, the later carb can be retrofitted by them, but major complicated.
And why bother, when so many other options exist? If the current distributor cap looks like a standard one, as opposed to the later duraspark which is distinctively larger, and "flatter", then you hopefully have a dual advance (vac and mechanical) distributor.
The dual advance dizzy that was used between after loadomatics is often referred to as a "thermactor" dizzy, as it arrived on the scene at the same time as the thermactor polution pump. They actually do not seem to have anything to do with one another, as far as I know. Just date of arrival.
If you pop the top off the dizzy, pull off the rotor (don't worry, it goes on only one way), you will see the top of the shaft. If its solid and sort of "D" shaped, then that would be the old loadomatic dizzy, which has only vacuum advance. The later dizzy will have a hollow, or "C" shaped shaft. You will find that the later C shaped shaft has some rotation in one direction (more than just your worn camshaft gear!!) That rotation is actually about 20 degrees and is the shaft rotating in the mechanical advance mechanism. It goes one way only, and springs back (springs are in there to counter the weights).
Hope this helps.
