I'm fighting a '66 170 motor with an Autolite 1100 and Load-o-Matic distributor.
Truck wants to die unless the choke is on. It's wanted to die out once warm with the choke pulled obviously. Timing is at about 8 degrees, but when revved up I'm getting no advance on the timing. Bad vacuum advance diaphragm on the distributor, maybe? Will a spark advance valve blow out like a Holley powervalve on a backfire? Carb rebuild was recent, but wondering if an backfire got it.
Vacuum is solid and steady at 20 lbs. Running Pertronix which seems to be functioning properly. Thoughts?
