Car started to be hard starting and rougher than usual idle. Had a look at the cap and rotor and found that they could stand to be replaced. Figured I would do the plugs as well. Not sure how many miles are on the stuff but its all 2 years old and its a semi daily driver during the summers so there are not 10's of thousands. Head was also rebuil/) t at the same time. Bottom looked good so I did not do anything with it. #1 was slightly white, 2 tanish white, 3 slight oil, 4 bordering on nasty oil, 5 sort of between 3 and 5, and 6 was pretty much solid white crust on one side and oil like crust on the other. They are autolite 46's gapped at 45 with a ds2 hei and blaster coil. Compression is about 8.3. 1100 carb. Since the head was rebuilt I dont think its valve guides. Compression was good 2 years ago so i dont think its compression rings. It runs good and strong like it always has its just got a rough idle which it has always had to a degree. I got to looking at spark plugs. Looking at Napa's site they pretty much call for a autolite 46 on all the 200's its just the gap that changes. Oddly in a champion plug the earlier ones call for a 22 and the later ones call for an 11. I am assuming a 22 is hotter (much hotter?) than an 11? So far I have not found any info that makes sense explaining the heat ranges between the brands.
Thoughts?
Thoughts?
